53 Users Online (52 Members):
Forums >> Revit Building >> Technical Support >> Annoying gutter join
![Jamie351 Avatar](user_avatar/249546.jpg)
![4 Stars: 7 Votes](/images/stars_4.gif) |
Hey guys I know technically a gutter wont go on the incline but in this case its small and one would be installed.
Is there a way I can place a gutter on here as if I take the long way and model it, still doesnt look very good.
Thanks.
Revit 2018........ |
That is sure a messy detail. I would probably never do that.
I would not incline the gutter because the typical installer couldn't do the transition. I would run the lower gutter straight back and if need me, use a downspout connector.
Water doesn't really run off the rake edge of the roof so you don't need the gutter there.
As you know a gutter will not follow a slope because they wouldn't really do this as WWHub stated. However if you NEEDED to do this you could but the gutter profile into a new profile family and use a Roof Fascia with a gutter profile to follow your roof lines instead.
In this case I'll just return it but if its on a garage on the boundary they do all the way along. Thanks for your help.
Gutter to extend when using join/unjoin roof |
Thu, Jul 2, 2009 at 8:40:03 PM
how to fix this gutter |
Wed, Dec 2, 2020 at 12:15:20 PM
Gutter display on roof plan |
Mon, Jun 11, 2007 at 3:47:21 PM
Wall join options |
Wed, Mar 23, 2011 at 7:46:49 PM
Gutter but what about gutter downpipe? |
Mon, Feb 22, 2016 at 12:31:57 AM
Members: | 2022361 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
