62 Users Online (61 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> curtain walling single door
Sat, Mar 4, 2006 at 1:32:24 PM | curtain walling single door
shaun
well ive got a smalle curtain wall inside my house design, i need to put a door in but can only find double doors, any1 got a single door i can use plz
Mon, Mar 6, 2006 at 1:49:15 PM | RE: curtain walling single door
PaulSweet
Look in Family Explorer. Doors - Glass - Single - curtain wall single glass al (Caution - I'm having trouble inserting this door and a double glass door in a plan I'm drawing, but I just started trying Revit, so I'm probably doing something wrong.)
Mon, Mar 6, 2006 at 2:12:50 PM | RE: curtain walling single door
gdoorn
1 Stars: 1 Votes
paulsweet - try subdividing the curtail wall with the curtain grid process in elevation. from there, you need to select a specific panel of glazing that you want to convert the door. you can tab through the highlighted selections until you get to the specific panel, then you can go to your options tool bar and pull down your panel options. if the doors have already been loaded they will appear here. you can change the curtain panel - clear glazing (or whatever the original panel was) and change it to the door-type you desire. i have been told the doors confine themselves to the panel you want, so if it is a double door you desire, you will need a 6' wide panel. hope this helps.
How to cut curtain walling and make a sloped wall?
Sun, Nov 20, 2011 at 2:42:36 PM
Revit 2015 Curtain Wall-Offset Pivot-Single Door
Thu, Aug 6, 2015 at 11:32:27 AM
Tags help please
Thu, Oct 23, 2008 at 3:48:47 AM
storefront doors in curtain wall
Mon, Mar 23, 2009 at 6:00:00 AM
Curtain Wall Panel to Curtain Wall Door
Page generation time: 1.0617
