81 Users Online (80 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Schedules - filtering by view or duplicate?
Mon, Jul 28, 2014 at 6:26:48 AM | Schedules - filtering by view or duplicate?
geraldrogers
I have a master schedule of rooms (with level, room number, name, area, department, occupancy etc..) on a sheet which is great. The building is 8 floors and I also have one sheet per floor. On each of these sheets I want to show the room schedule for just that floor (i.e. by filtering the master schedule and putting it on the sheet along side the floor plan).
The way I have done it is by duplicating the master schedule and using the filter to remove the information that I don't require. It means I have numerous schedules (one for each floor). This is ok and seems to work fine.
However, is this the correct Cryingbest) way to do it?
Or is there a way to do this in the visibility/graphics for the sheets by creating a filter of the view there? I set up what I thought were filters in this but they don't work.
Gerald Rogers
Revit 2015
Mon, Jul 28, 2014 at 7:50:50 AM | Schedules - filtering by view or duplicate?
I believe you are doing it correctly as long as you are simply filtering the copied schedule by level.
Mon, Jul 28, 2014 at 8:24:37 AM | Schedules - filtering by view or duplicate?
geraldrogers
Yes, that is what I am doing. Thanks!
Gerald Rogers
Revit 2015
Filtering in Schedules
Mon, Feb 4, 2019 at 11:41:18 AM
Unable to duplicate a view
Tue, Sep 13, 2011 at 6:44:22 PM
Duplicate view
Wed, Jul 15, 2015 at 1:50:19 PM
Problem with Duplicate Schedules
Fri, Jun 29, 2012 at 9:44:56 AM
Duplicate elevation view
Wed, Jan 11, 2006 at 4:41:28 AM
Page generation time: 1.0646
