72 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Can you tell a building pad to cut multiple toposurfaces? Revit 2014
Thu, Jul 24, 2014 at 11:39:00 PM | Can you tell a building pad to cut multiple toposurfaces? Revit 2014
thinktank
Hi,
I often use 2 toposurfaces to show both the natural ground level and the surveyed ground levels. I would like to then use a building pad to cut in the basement, but when I add the pad it is only cutting through one of the toposurfaces (the one I modelled first). Is there a way to make a building pad cut through multiple toposurfaces? Revit Architecture 2014
Fri, Jul 25, 2014 at 7:08:01 AM | Can you tell a building pad to cut multiple toposurfaces? Revit 2014
It will cut only the one surface.
Not sure what the difference would be between "... natural ground level and the surveyed ground levels..."  Seems to me they are the same thing.  Or do you mean proposed instead of one of these?  If so, then you should be using graded regions.
Mon, Aug 11, 2014 at 11:27:46 PM | Can you tell a building pad to cut multiple toposurfaces? Revit 2014
thinktank
The Natural Ground Levels are the levels that council have recorded  - also called the Original Ground Levels - what the ground was doing before anyone built on it. We have to measure building height from these levels. But then the Surveyed Ground Levels are what the site looks like now, often filling has taken place, and we need the surveyed ground levels to work out the site access, driveway grades, floor levels etc. Just would be handy if the building pad could cut multiple toposurfaces.
Tue, Aug 12, 2014 at 2:45:16 AM | Can you tell a building pad to cut multiple toposurfaces? Revit 2014
ronmalit
5 Stars: 3 Votes
your natural ground level, if cut, is already your new surveyed ground levels. so why would you show natural ground level with cut?
if you really must do this way:
what i normally do is copy the topo side by side, and having a reference line as my copy basepoint, i now copy all building pad.
this way i will have multiple topo with same building pad.
in the attached photo. i have one revit file, 3 exactly same topo, and copies of building pad in different formation level.
hope this gives u idea.
working with Pads and toposurfaces
Fri, Jun 8, 2007 at 3:17:49 PM
Building Pad Problem
Thu, Dec 20, 2012 at 3:51:08 PM
Building Pad Schedule
Wed, Apr 23, 2008 at 11:12:39 AM
How do I modify building pad in Revit Structure 2012?
Mon, Aug 22, 2011 at 5:15:25 PM
Building Pad
Thu, Sep 30, 2010 at 11:41:28 AM
Page generation time: 2.5283
