72 Users Online (71 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Linked Files – Master plan file - Room Tags, Gross Areas etc.
Thu, Jul 24, 2014 at 10:01:54 PM | Linked Files – Master plan file - Room Tags, Gross Areas etc.
Reddrev
Revit 2014
I am designing a commercial retail village.  There are 12 standard building types, that will be linked into a master plan file at various locations and orientation, resulting in around 60 buildings in total.
I want to room tag and calculate internal retail space and gross areas in the master file. The function of each room space within the 12 building types will change depending on its location within the master plan.
My aim is to be able to place all the linked buildings in the master plan, and then tag each space with a unique identifier that is sequenced across the entire master plan and scheduled accordingly.
I seem to be having a few problems:
1.         In the original file, all retail space has external and internal bounding walls and it is possible to area tag each space within that file.  However when placed as a linked file (with “Room Bounding” on), and  placing a room tag in the master file, the tag measures to the internal face of the external walls, ignoring the internal bounding walls that create each retail space.
2.  If I create room tags in the original file. Then I can use the “Tag Room” in the master plan file and it will apply a label to each room, but that new tag is not editable, so I can’t use the tag sequencing and naming ( the same building type could be a retail space in one location and labeled “retail”  and in another location labeled “Café” ).
3.  I can’t get gross areas to be created automatically in the master file from the linked files external walls, I need to use the “Area Boundary” tool and manually create all the gross area boundaries.
Many thanks for helping me understand this.
Fri, Jul 25, 2014 at 7:26:57 AM | Linked Files – Master plan file - Room Tags, Gross Areas etc.
The only real way to do what you want is to link the buildings as room bounding then adding all rooms in your model.
Good luck.... If there is very much to any of these buildings you could have problems and you will definitely have problems with levels if the site is not flat.  (You would need seperate levels for each building.)
Wed, Jul 30, 2014 at 8:40:52 PM | Linked Files – Master plan file - Room Tags, Gross Areas etc.
thangact
For your questions, i have some suggestions:
1. i'm not clear about this. Could you show images for my reference.
2. In this case, you are able to use design option for ROOM. In central file (where placed linked files), can use  VV(VG) to control design option for each linked file.
3. You can create area boundary automatically, but (normally), it's not really good for what you want. It should be redrawn or create new at the first time.
Room Tags not visible in a linked file - Revit 2014
Tue, Apr 4, 2017 at 5:54:04 PM
How to make room tags in a linked file visable?
Thu, Jul 30, 2015 at 1:12:22 AM
2011 - Room Tags from a linked file
Thu, Aug 19, 2010 at 4:10:54 PM
Linked file Room Tags
Wed, Apr 17, 2013 at 1:08:27 PM
looking for a keynote master file workaround
Fri, Apr 3, 2009 at 6:57:06 PM
Page generation time: 2.5592
