34 Users Online (32 Members):
Forums >> General Discussion >> Revit Project Management >> problem in 3D and elevation
when i go to 3d or elevation, the model is very small hard to find it, everytime i go to 3D, i need to zoom it first before i see it...
![3.5 Stars: 393 Votes](/images/stars_3.5.gif) |
While it is very small, window the screen. You will usually find something way off in space from your model. Delete that.
how caan i find that?
As I said "....window the screen. " This is a fundamental Revit tool. Meaning use a pick window to select all the objects. You should find some indicators far away from your model. You can zoom in there and look at them. Delete anything that is junk.
thank you so much...
over-riding elevation tags |
Wed, Oct 1, 2008 at 3:37:15 PM
Change spot elevation dimensions 0.00 coordinate |
Sat, Feb 4, 2012 at 10:56:05 AM
Elevation Tag - Leader Problem |
Thu, May 17, 2012 at 5:48:20 PM
Spot elevation symbol [ 1 2 ] |
Mon, Dec 1, 2008 at 10:10:59 AM
16
Elevation Callout loading, but can't be used |
Wed, Jul 28, 2010 at 12:48:03 PM
Members: | 2026126 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
