Forums >> Revit Building >> Technical Support >> Inclined curtain wall
43 Posts No Rating |
Greeting ,
Want to ask, about the best way,
To model inclined curtain wall, without using mass
Thanks for all
Either a mass - face based - or model in-place - modeling all elements (non-system).
Or you could build in a family.
Edited on: Wed, Jul 23, 2014 at 7:35:29 AM
Thanks, will try it....
I try it with roof by footprint, command
added slop arrow , with hard slope
Seems it is good, I can add my curtain grid and mullion
On it....
Pls advise
No. You can create a sloping roof but you can't put curtain wall components on that.
Use the mass.
Yes, you can start with a sloped roof by footprint and then add curtain panels and mullions. Simply change the roof type to be "sloped glazing" and then go to Edit Type and configure the properties of the mullions and panel.
Planta1 Revit Online Consulting | info@planta1.com |
Alf,
I'm glad you posted that. As many times as I do a roof you would think I could remember that you have that type choice.
Thanks
No problem. See? I am paying attention.
yes it work, but as proffessional users, better to model it in a mass command
I think the roof sloped glazing is far easier to modify than using the mass.
"...but as proffessional users, better to model it in a mass command..." << I don't understand this conclusion.
Is it a wall or is it a roof? Although the system schedules as a roof, there is no associated area. The mass created CW system is neither a roof or a wall and both "surfaces" are in the same schedule - again without area. The panels and mullions all schedule under CW components for both mass created and roof created.
Agree with you
Windows/opening/curtain system on inclined wall |
Tue, Apr 21, 2009 at 5:16:46 AM
editing an inclined wall |
Tue, Apr 26, 2011 at 4:05:46 AM
adding a parameter in an inclined wall family |
Mon, Dec 29, 2008 at 5:29:49 PM
Curtain wall assigned to inclining surface of SweptBlend​? |
Thu, Dec 13, 2012 at 4:17:34 PM
concrete beam on top of inclined wall |
Wed, Jun 20, 2007 at 11:09:18 AM
Members: | 2097787 | Objects: | 23164 | Forum Posts: | 152288 | Job Listings: | 3 |
