Forums >> Revit Building >> Technical Support >> material and sq.ft. of the wall (schedule)
Fri, Mar 3, 2006 at 12:12:07 PM | material and sq.ft. of the wall (schedule)
Reviter
5 Stars: 2 Votes
Hi, does anyone know if Revit can give a schedule on material sq.ft. and cost? I need to do a project with about 100 houses and need to calculate the sq.ft. of materials, such as, drywall, stubs, roof area, windows and door. by the way, I noticed that the tag on the windows and door shows only the type mark. Is there any way to assign different number to different window/door even they are the same type? thanks all for you help. ^^
Schedule material mark in schedule type other than material Schedule?
Wed, Jun 22, 2011 at 3:59:07 PM
Schedule material mark in door schedule - Revit 2014
Fri, Jan 19, 2018 at 2:57:03 PM
Material schedule not picking up materials in railing object
Fri, May 6, 2011 at 4:03:35 PM
material tag schedule problem
Sat, Mar 25, 2017 at 7:50:36 AM
Differences between Schedule and Material Takeoff Schedule?
Thu, Feb 9, 2012 at 7:31:53 AM
Page generation time: 1.2626
