49 Users Online (48 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Instance Parameter On Keynote Tag
Thu, Jul 17, 2014 at 3:18:22 PM | Instance Parameter On Keynote Tag
RockFish
5 Stars: 2 Votes
Okay, so I am thinking of using keynotes to speed up my noting of building sections.  I constructed this really great (okay maybe just partially great) tag that I can adjust the text box width and justification by visually hiding 9 of 10 lables controlled by instance parameters.  This way I can just click a box to say if the tag is left or right justified and pick an inteter 1-5 to control how long the string of text is before it wraps.  I even put in an invisible line so the leader comes off the top line of text and not the middle.  So, when I put it in the project the instance parameters don't show up in the properties menu.  Right now the only way I see to control these parameters is by making them type parameters that would require me to make 10 different types (yuck).  Does anyone know how to get around the instance parameters not showing up on the tag preperties menu.  I have attached my really partially great tag.  Oh, and I am working in Revit 2015.
Tue, Jul 22, 2014 at 11:14:29 AM | Instance Parameter On Keynote Tag
RockFish
5 Stars: 2 Votes
I am guessing from the lack of response nobody wants to give me the bad news Sad  I just saw another post on another website pretty much saying that as of Revit 2014 you cannot put instance parameters on tags.
Keynotes & Door Schedules - keynote field - change to instance parameter?
Fri, Oct 17, 2008 at 3:47:42 PM
Change Keynote to an Instance Parameter?
Wed, Jul 23, 2014 at 2:37:36 PM
Keynote Tag defaulting to Category Tag
Fri, Jul 20, 2018 at 11:20:17 AM
Adding Optional Text Field to Keynote Tag
Thu, Nov 13, 2008 at 8:52:47 AM
keynote categories
Fri, Aug 10, 2012 at 3:56:23 PM
Page generation time: 2.6768
