41 Users Online (39 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Subfloor Vs Finish Floor Elevation
Mon, Jul 14, 2014 at 3:59:10 PM | Subfloor Vs Finish Floor Elevation
blue442
blue442 Avatar
What do you guys do?
We want / need use "FIRST FLOOR SUBFLOOR" over F.F.E. for our dimensioning.  As a solution to the spot elevation issue we had (spot elevations reading "100-0 3/4") we opted to omit the finish floor out of our floor assembly and move all of our doors 3/4" above this level.
the problem is that i now see dual lines below the doors.  Obviously this was unintended.  And it makes sense they are there... So the only option i think i have is to add the finish floor back into the floor assembly and deal with the spot elevations being off by 3/4".
Is there another way to achieve what we're trying to do, or do we just need to adapt to seeing 100'-0 3/4" for a F.F.E. versus a 100'-0" T.O. Subfloor.
Thanks!
Tue, Jul 15, 2014 at 2:23:27 AM | Subfloor Vs Finish Floor Elevation
ronmalit
5 Stars: 3 Votes
hi,
im confused but I want to help,
we normally model it separately (not as an assembly)
one floor type for Subfloor, and one floor type for FINISHES
for the spot elevations, we will tag the FINISHES, spot elevation can show both/or either top and bottom elevations.
so we will have 100'-0 3/4" and/or 100'-0" (on your example)
hope it helps
** dont be mad, i dont have much... i am homeless
Tue, Jul 15, 2014 at 7:38:12 AM | Subfloor Vs Finish Floor Elevation
We don't typically reference "finish floor".  Our floors are the structural floor with sub-base.  Typically, this is what all interior framing is built on so the level is set to the top of this floor.  That means all doors and walls and woodwork is referenced off this level and that is really how we build typically.  Ceramic floors / carpet (if shown) / RVT and wood wood be thin floors modeled on top of this floor.
Obviously, if you have raised computer floors (we add a new level) or some form of floor thicker that 1/2", you may do something different.
Tue, Jul 15, 2014 at 7:58:05 AM | Subfloor Vs Finish Floor Elevation
blue442
blue442 Avatar
That sounds like the solution... We'll model a second floor on top of the sublfloor.  it would be pretty easy to do so. It makes a difference in our stairs.  They need to go from Basement (Slab On Grade) to First Floor Finish Elevation (not subfloor).
Thanks guys!
I'm not sure why i did not think to model the finish floor seperatly then have the spot elevation read "bottom of".
Adjusting model from finish floor to subfloor
Wed, Feb 26, 2014 at 2:12:06 PM
Getting floor elevation to be at subfloor....
Sat, Apr 18, 2009 at 10:49:02 AM
civil changed our Finish Floor Elevation 3 inches (2017)
Tue, Dec 13, 2016 at 12:54:13 PM
Where does it start and ends the slab?
Wed, Dec 23, 2009 at 11:25:28 AM
Finish Flooring as part of Structural Floor assembly
Fri, Dec 26, 2008 at 8:42:15 PM
Page generation time: 0.6429
