24 Users Online (23 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Creating a Project Parameter that Corresponds to View
Wed, Jul 9, 2014 at 10:20:00 AM | Creating a Project Parameter that Corresponds to View
jsego
Hello,
I am trying to create a workaround for the fact that Revit is unable to display lineweights correctly in elevation views.  Does anyone know how to setup custom/instance/Project Parameters corresponding to each elevation view, for the objects (like walls) to be overridden?
Thank you!
Wed, Jul 9, 2014 at 10:25:45 AM | Creating a Project Parameter that Corresponds to View
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Take a look at this post, it may help you
http://cad-vs-bim.blogspot.com/2010/10/are-revit-elevation-views-leaving-you.html
Wed, Jul 9, 2014 at 10:32:23 AM | Creating a Project Parameter that Corresponds to View
jsego
Thanks for the response.  That's funny that you posted that because that's what I'm looking at.  He says about halfway through "On a real project I suggest that you setup custom/instance/Project Parameters corresponding to each elevation view, for the Objects to be overridden (walls in this case): perhaps they look similar to Image 11 & 12's List of Potential Instance Parameters for Walls to be overridden using the Filter Method:" But I don't know how to do this!
Wed, Jul 9, 2014 at 12:12:35 PM | Creating a Project Parameter that Corresponds to View
Read your Help on how to create filters.  You can apply the filters by view or by element instance.  Filters can be set to apply to different or multiple categories, disciplines and selected project parameters.
http://help.autodesk.com/view/RVT/2015/ENU/?guid=GUID-1E2EABAD-EAED-4521-8FB2-33D0B4FCAAF8
Wed, Jul 9, 2014 at 12:17:03 PM | Creating a Project Parameter that Corresponds to View
Pikachu123
What you could do is set up a template for section views, and everytime you make a new section view assign your template to it. The template should incorporate overrides for line weight in the correct model category of element you want to modify. So in the template you would go to the model tab>go to walls row>click on the "lines" column click twice>change the line weight to what you want them to be. If this doesn't fix it you will need to set the Line thickness for each of the numbered categories,i.e. 1,2,etc. you can find that menu in the manage tab>Additional setting>line style, here you can set the thickness to what number you assign the override to, be careful though because this will affect your other line weights, unless you create a new style and override the line style with the one you just created. and also watch out because eah line thickness depends on what scale you are in as well. hope it helps.
View Parameter & Label
Mon, May 15, 2017 at 4:53:26 PM
Add Parameter to Family Category - View Title
Tue, Jan 17, 2012 at 2:28:48 PM
"group parameter under" changed upon loading into project
Wed, Aug 11, 2021 at 3:16:03 PM
Creating Uneditable Parameter?
Wed, Mar 12, 2014 at 12:50:31 PM
How do you share a parameter between several different sheets?
Thu, Nov 10, 2016 at 3:15:54 PM
Page generation time: 2.2450
