49 Users Online (48 Members):
Forums >> Revit Building >> Technical Support >> Interior Elevation Option is not available
Using Revit 2013
The only option to create an interior view is to use the Building Elevation family which has the wrong graphics. The option is not available in the properties drop down menu and therefore I cannot change the type.
Any suggestion would be greatly appreciated
Than you very much
Christian Fekete Architect
First - do you have all 3 updates installed for 2013?
Someone must have deleted it the type you want so simply create a new type. DUPLICATE!
I found the solution, I created an interior elevation view type then, changed the elevation tag to a circled 1/2" and revit handled the rest, it works.
Thank you very much for responding
Best
CF
Interior Elevation not visible in drop down |
Thu, Feb 6, 2014 at 9:19:32 AM
Interior Elevation Tags |
Wed, Oct 9, 2013 at 2:23:36 PM
Revit 2011 Multiple Interior Elevation References |
Wed, Oct 26, 2011 at 9:01:48 AM
Interior Elevation Tag missing from drop down |
Wed, Aug 18, 2010 at 4:28:45 AM
Using Visibility Graphics to control elevation callouts |
Wed, Nov 12, 2008 at 9:58:42 AM
Members: | 2022391 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
