34 Users Online (33 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> transparent columns
Tue, Jul 8, 2014 at 6:59:59 AM | transparent columns
frankieright
Walls that go through structural columns show, as if the column is transparent.  The fill is hidden, but the edge is not.  Does not happen with all columns - seems random.  I am using a view template, so it should be the same in all views, but is not.
Tue, Jul 8, 2014 at 8:21:06 AM | transparent columns
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Attach an image of your problem.
Tue, Jul 8, 2014 at 8:46:35 AM | transparent columns
frankieright
Here is the image.  Vast majority are transparent.  Also, I am using Revit 2015.
Tue, Jul 8, 2014 at 9:27:54 AM | transparent columns
We have now seen several posts on this subject yet I can't reproduce the problem.  That's why I think this is a process error but I don't know what that is.
Please analyse your process and post it.  That includes the properties of the effected items including family, element properties showing level and height, element phase, view settings for phase, phase filter and discipline.
You may want to just do this in a seperate area or project and see if you can recreate the problem.
Tue, Jul 8, 2014 at 12:13:23 PM | transparent columns
frankieright
Ok, I'll let you know our results.
Tue, Jul 8, 2014 at 1:15:47 PM | transparent columns
frankieright
We have found the cause (but not the fix):  See attachment.  Columns are opaque on 4th floor west but not on 3rd floor west.  The become transparent when we add beams.  See the section cut.  There are beams at 3rd floor west.  We tried all combinations of attaching and detaching the columns to and from the beams, with no results.
Thu, Jul 10, 2014 at 9:08:06 AM | transparent columns
frankieright
Hi, has anybody found a solution to this problem?  As I said in the previous post, we did determine the beams were causing the problem, but don't know how to fix it.  We even detached the beams completely.  It's a huge drawing set, and we really need to solve this graphic issue.  Can't make columns black, because they are existing.  Adding masking regions to all columns in all plan views will take days.  Any ideas??
Wed, Jul 23, 2014 at 9:10:42 AM | transparent columns
frankieright
Still no solution to my problem - Is anybody out there?
Wed, Jul 23, 2014 at 9:24:59 AM | transparent columns
Send the problem to autodesk!
hidden columns
Fri, Mar 26, 2010 at 10:53:36 AM
Showing columns from the floor above
Mon, Jun 9, 2008 at 1:49:48 PM
Transparent object
Tue, Sep 14, 2010 at 1:18:34 PM
Creating transparent material such as 3FORM
Wed, Aug 26, 2009 at 8:09:06 AM
elevations have gone transparent
Wed, Jun 6, 2012 at 6:02:04 PM
Page generation time: 1.4258
