172 Users Online (171 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Turning 'Ortho' Off
Thu, Mar 2, 2006 at 9:42:24 AM | Turning 'Ortho' Off
DonWhite
Is it possible to turn off the snap to horizontal or vertical when trying to draw lines at shallow angles like 1/8" per foot?
Thu, Mar 2, 2006 at 12:24:33 PM | RE: Turning 'Ortho' Off
arccodex1
3 Stars: 1 Votes
Snap Off (SO)
Mon, Mar 6, 2006 at 5:49:27 PM | RE: Turning 'Ortho' Off
DonWhite
Thanks...so obvious.
Tue, Mar 7, 2006 at 9:00:57 AM | RE: Turning 'Ortho' Off
jontramos
FYI, Another way to temporarily turn off the "Ortho" effect is to tap the TAB key. This works great if you only need to turn it off for just one quick shallow angle, but then want it back on again after that. I discovered this trick by accident a few weeks ago, & it has come in pretty handy since. Got to love the magical TAB button (is there anything it can't do?)
-Jon www.mds-bos.com
Thu, Mar 28, 2013 at 2:52:15 PM | Turning 'Ortho' Off
oritreuben
NO!!!!!!!!!!!!!!
Snap is NOT the same as ortho!!!!!!!!!!
How do you turn Ortho off??????
Thu, Mar 28, 2013 at 2:57:04 PM | Turning 'Ortho' Off
As the post above you says.... hit the tab key.
Mon, Dec 9, 2013 at 5:14:33 PM | Turning 'Ortho' Off
raremud
How do you set this reverse? I mean...without cliking anything to have free control and if you hold TAB key down it becomes Ortho? Any help?
Mon, Dec 9, 2013 at 9:18:29 PM | Turning 'Ortho' Off
grid
Also make sure the 'constrain' box is un-ticked just below the ribbon.
Palm Springs Architect using Revit LT!
Tue, Jan 12, 2016 at 2:07:01 PM | Turning 'Ortho' Off
boboliano
in Revit 2015, for me holding down the Shift key worked.
Ortho Maybe
Mon, Jun 18, 2018 at 10:39:12 AM
ortho 3d view??
Mon, Jul 10, 2006 at 12:59:11 PM
''Visibility grafics'' and ''create parts'' problem when mak
Fri, Mar 19, 2021 at 11:45:46 AM
Hiding Demo'd Garage Doors
Wed, Aug 10, 2005 at 8:02:23 PM
Rendering without ground plane
Tue, Dec 6, 2005 at 2:22:45 AM
Page generation time: 0.7142
