53 Users Online (51 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Rendering Problems...
Thu, Mar 2, 2006 at 9:38:33 AM | Rendering Problems...
nscshwn08
using Revit 8.0, and trying to render a project for local astronomy club. The project rendered fine the first time, since then any rendering shows the site, which is grass, with grey lines running throughout. This has occured on 2 different computers, using 2 seperate editions of Revit. I even deleted the site, and then redrew the site, and the problem reoccurs every time, so i believe it has to be a setting within the file. Any ideas? Also, what is the correct way to get a image to display behind a rendered outdoor scene? After importing the file, and setting it as the background, it renders as a solid gray box? Im going nuts! this all worked before! HELP!
Thu, Mar 2, 2006 at 11:05:44 AM | RE: Rendering Problems...
K-Pax
Interesting to say the least... can you post a screenshot of what is happening in each instance? thanks, Kyle
Thu, Mar 2, 2006 at 11:25:06 AM | RE: Rendering Problems...
nscshwn08
Wow, i just went back in and region rendered it for the screenshot, and it did it correctly, go figure. I did however find out that when it was having the problem, if i raytraced the entire area, it would render correctly...maybe the software hates me??? I still have the issue of the background file not showing up in the render however, and that is confusing, if you have any ideas on that, would love to hear it! Thanks for your response! Shawn
Problems with Best quality nighttime rendering.
Tue, Dec 4, 2012 at 8:32:14 PM
Rendering Problems
Wed, Jun 18, 2008 at 6:48:30 AM
12
Rendering problems
Tue, Sep 12, 2017 at 9:55:22 AM
help with rendering!
Wed, Aug 10, 2016 at 10:47:18 PM
Can a 63mb Revit File Size cause problems during rendering?
Mon, Nov 2, 2015 at 6:29:46 AM
Page generation time: 0.5625
