80 Users Online (78 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Door with window panels that can be turned on and off
Tue, Jul 1, 2014 at 11:33:46 PM | Door with window panels that can be turned on and off
aehryl
This family drive me nuts. I tried doing it but everytime i put 0 on the length/width of the window panel in the door, revit deletes the whole entity.
Do you have any idea how to do this? Please tell me.
Thank you
Wed, Jul 2, 2014 at 7:19:55 AM | Door with window panels that can be turned on and off
What family?
Wed, Jul 2, 2014 at 1:14:13 PM | Door with window panels that can be turned on and off
aehryl
It was a test. I failed doing it. The problem was to create a door that it's window panel can be turned on and off. Help me please
Wed, Jul 2, 2014 at 1:15:28 PM | Door with window panels that can be turned on and off
Download the Families Guide from the autodesk site.  It will show you how to control visibility of family elements.
Wed, Jul 2, 2014 at 11:03:52 PM | Door with window panels that can be turned on and off
CDWdavid
5 Stars: 5 Votes
Hi Aehryl,
You may try this.
http://www.revitcity.com/downloads.php?action=view&object_id=11969
I was using the visibility to control the lights configuration.
Thu, Jul 3, 2014 at 1:22:04 AM | Door with window panels that can be turned on and off
aehryl
Thank you all for your kind response. I will try everything you told me. I hope I could make this right. Thanks :3
Curtain wall Panels Pre-delevoped Adding a Door or Window?
Fri, Jan 20, 2012 at 7:55:06 AM
Window panels that adds up! :3
Tue, Jul 1, 2014 at 11:11:16 AM
Can't select door/panels in storefront
Sat, Aug 15, 2009 at 7:34:43 AM
Multi Panel Sliding door that is actually a Window Family
Fri, Feb 20, 2009 at 7:22:04 AM
Placing window at intersection of 2 precast concrete panels
Sat, Jan 5, 2008 at 7:57:00 AM
Page generation time: 19.8391
