70 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> Newbies >> using sweeps to make cabinets
Tue, Jul 1, 2014 at 12:52:49 PM | using sweeps to make cabinets
bgonte
Hello!
I am currently trying to make the body of a cabinet with a sweep, but I do not know what profile to select so that I can adjust the height! I selected path I wanted and loaded a profile, but do not understand how to adjust the height.  I am assuming I am loading the wrong thing.  Or can I even make a body of a cabinet with a sweep.  It looks like the body of the cabinets within Revit are built using a sweep.  Any advice would be great!!!
Thank you
-Brittany
Tue, Jul 1, 2014 at 1:04:53 PM | using sweeps to make cabinets
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You need to use reference planes to align and lock your cabinet height to the reference plane. Then you can use the Height parameter to adjust the height (or make one if you havent yet.
Tue, Jul 1, 2014 at 1:19:32 PM | using sweeps to make cabinets
bgonte
Can I adjust sweep heights with parameters?
Tue, Jul 1, 2014 at 1:27:10 PM | using sweeps to make cabinets
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Yes that is what I just told you "Then you can use the Height parameter to adjust the height (or make one if you havent yet."  But you need to create them.
Tue, Jul 1, 2014 at 2:01:37 PM | using sweeps to make cabinets
bgonte
The reason I asked again is because everytime I try to use a parameter to flex a profile it says that it cannot make an extrusion.
Tue, Jul 1, 2014 at 2:11:13 PM | using sweeps to make cabinets
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Then you have done something wrong.  Way to many variables for me to answer without seeing your family.
Tue, Jul 1, 2014 at 2:42:07 PM | using sweeps to make cabinets
bgonte
I attached the family of casework that I am trying to build.  So far all there is, is a toe kick, 2 front panels, and a sweep.  I want that sweep to be 34.5" high, but even when i use reference planes and then attach dimensions and add parameters I cannot seem to flex my sweep If you have any idea what I am doing wrong that would be great.
Tue, Jul 1, 2014 at 2:46:45 PM | using sweeps to make cabinets
bgonte
Actually looks like the file was too big to send is there anyway I could email it to you?
Tue, Jul 1, 2014 at 3:09:34 PM | using sweeps to make cabinets
A casework family was too big to attach?  If that's true then it's too big to use in a project!
Are you using a buch of CAD in that family?
Cabinets only are inserting dashed
Tue, Oct 26, 2010 at 10:25:29 AM
How do I add crown molding to wall cabinets?
Mon, Sep 22, 2014 at 7:13:43 AM
Creating furr downs above cabinets...
Fri, Jul 13, 2012 at 8:36:37 AM
Outlets and Wall Sweeps
Wed, Feb 29, 2012 at 9:39:46 AM
Floor tile patters show under cabinets
Sun, Mar 25, 2007 at 11:08:03 PM
Page generation time: 0.9061
