98 Users Online (97 Members):
Forums >> Revit Building >> Technical Support >> Controlling the Lineweights of Window Subcategories using Filters
20 Posts No Rating |
I am trying to show the "beyond" look in my elevations using filters. This blog best explains what I am trying to do: http://cad-vs-bim.blogspot.com/2010/10/are-revit-elevation-views-leaving-you.html . I have labeled all my walls and wall sweeps with different comments to try to achieve the look we want. I ran into an issue where I want the casing of my windows to appear darker than the rest of the window relative to the wall it is placed in. For example, if the projection lines of my wall are a lineweight of "3" then I want only the casing of my window to be a "3." Same goes for projection lineweights 2 and 1. I know I can change the subcategory lineweight universally using object styles, but is there a way I can filter just the subcategory of my window like I filtered my walls so that I have windows with different casing lineweights in a single elevation?
Thank you!!
Filtering Window Subcategories |
Wed, Jul 9, 2014 at 7:51:35 AM
Lineweights For System Filters |
Mon, Apr 20, 2015 at 2:28:08 PM
Controlling Line Weights with Filters |
Tue, Dec 10, 2013 at 11:53:50 AM
phase filters and lineweights |
Fri, May 22, 2009 at 3:15:11 PM
controlling lineweights of extrusions/sweeps in plan and elevation views? |
Fri, Jan 23, 2015 at 8:28:20 AM
Members: | 2017072 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
