Forums >> Revit Structure >> Technical Support >> Construction Phases
Hello,
I want to get into the phases tool of Revit. At this point the only way I can see everything in 3D is if I model in Substructure phase. If I make walls in interior construction I cannot see the walls in 3D. Basically, I only model/draft in substructure. However, I would like to draw things in different phases thinking I could organize the project. Anywhere I can learn this would be great. I guess I just dont understand the whole thing.
Thanks
Bjenk8100 |
Who set up your phases? Substructure and interior construction are not phases, those are areas that could go on Worksets if necessary. Existing, New and Demolished are phases. Take a look at this post for an example
http://www.revitzone.com/revit-fundamentals/62-phases-an-overview-of-revit-phases
sorry I meant 3D views.
Bjenk8100 |
Sorry for confusion. This is what I mean. I draw on a floor plan. If you look at properties and go all the way down to phasing, A10-Substructure is selected. If this is selected I can see everything in 3D. If I choose C10-Interior Construction I cannot. This template was based off of Revits Construction Template.
Bjenk8100 |
We don't use the construction template but the idea would still be the same as the link that I sent you. The reason you cant see anything when you set it to C10 -interior is because everything that you placed was placed on the A10-Substructure phase.
Phases |
Tue, Aug 26, 2014 at 7:25:07 AM
Painting walls across phases |
Thu, Dec 26, 2013 at 12:36:58 PM
Pads and phases |
Wed, Mar 28, 2018 at 6:44:34 AM
Cutting a Column for Different Phases? |
Tue, Jul 2, 2013 at 9:05:31 PM
Ghost Phases |
Mon, Mar 24, 2014 at 5:08:47 PM
12
Members: | 2115007 | Objects: | 23192 | Forum Posts: | 152319 | Job Listings: | 3 |
