58 Users Online (56 Members):
Forums >> Revit Building >> Technical Support >> Revit 2014: family templates are missing
Hello! I am trying to create a new family. So I go to families>new and the folder is empty! What do I do??
You may have installed them elsewhere. Under the Revit R dropdown/options, you will find the pointers to your file locations. Use window's exployers to find where you installed these files then set the pointers to the correct location.
If you truely did not install the library, then you will have to do that again.
![5 Stars: 5 Votes](/images/stars_5.gif) |
This is for 2015, you may try to see if Autodesk had a similar fix for 2014.
http://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Revit-2015-Templates-and-families-not-installed.html
I actually already looked that up, but I did not seem to be able to find a similar fix for 2014.
revit 2014 templates is denying access |
Wed, Oct 29, 2014 at 7:36:22 AM
Where have my templates gone in 2012 |
Sat, Apr 7, 2012 at 9:09:06 AM
Default templates and families missing from Revit 2016 |
Sat, Jul 15, 2017 at 10:14:48 AM
Lack of templates and families in revit 2014 |
Fri, Dec 5, 2014 at 4:34:23 PM
2012 No Templates or Family Files |
Thu, Oct 13, 2011 at 11:35:26 AM
Members: | 2022345 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
