66 Users Online (65 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Revit Project Management >> Why column look like this?
Wed, Jun 18, 2014 at 10:37:46 AM | Why column look like this?
aaurnab
aaurnab Avatar
2.5 Stars: 3 Votes
Same Family but wall pssing though into one column and another isn't.
please help me to find this problem.
Wed, Jun 18, 2014 at 10:48:34 AM | Why column look like this?
Not enough information.
Revit you are using?  Updates you have installed?
You say "same family"  << What are you saying ? ... same wall family?
We need to know are these architectural or structural columns?  What family?
Are these in-place or system family walls?
Are you using phases?  If so, are all these components the same phase?
Thu, Jun 19, 2014 at 2:04:25 AM | WWHub
aaurnab
aaurnab Avatar
2.5 Stars: 3 Votes
Quoting WWHub from 2014-06-18 10:48:33
Thanks for Instant reply, This colunm are in same family and Architectural column...and wall are also in samesystem family wall family , when attach colunm to top base then wall is showing itself  in some colunm.
Thu, Jun 19, 2014 at 6:59:23 AM | Why column look like this?
I asked about what Revit release and what updates because that is important.  Verify that you have all your updates installed, we can not help you if you don't.
Thu, Jun 19, 2014 at 8:29:40 AM | Why column look like this?
Junmo
Hi there, you might need to check if the wrong column's constrain, do they have the same constrain with other right columns? I doubt they did not sit on the floor level so that they were not cut by the cutting plane. That is to say, they were above the cutting plane.
Freelancer for Revit Modeling and Drafting Service.
More information please contact: junmodesign@foxmail.com
Mon, Jun 23, 2014 at 9:14:42 AM | Why column look like this?
aaurnab
aaurnab Avatar
2.5 Stars: 3 Votes
Thanks Both of you WWhub and Junmo, All the column is in same constrain. I did "creat similer" and put on the wall and it was Ok. I think this problem is for not updating my Revit. Now I use Rev2015 and wall not shwoing into column after I attach to the Top base.
Thanks a lot
Edit: the problem seems again....attaching Top base the wall shows in columns...
Edited on: Tue, Jun 24, 2014 at 3:29:15 AM
Tue, Jul 1, 2014 at 7:03:29 AM | Why column look like this?
JohanEkstrom
Have you checked the settings of "Show family pre-cut in plan views" in the rfa-file?
Edit family -> Family Category and Parameters -> Show family pre-cut in plan views
Thu, Jul 3, 2014 at 4:09:35 AM | JohanEkstrom
aaurnab
aaurnab Avatar
2.5 Stars: 3 Votes
Quoting JohanEkstrom from 2014-07-01 07:03:28
Yes it's is already checked. when column attached to top floor, the walls shows in to the column
DISPLAY COLUMN LABELS
Wed, Sep 8, 2010 at 3:53:42 AM
Column Capitals
Wed, Sep 18, 2019 at 8:39:08 AM
L shaped column
Mon, Jun 22, 2015 at 4:37:30 AM
Top of Isolated Column Footing forced to snap to bottom of column
Mon, Jan 13, 2014 at 7:41:44 PM
WT column - help?
Fri, Jun 14, 2013 at 9:10:50 AM
Page generation time: 0.2509
