49 Users Online (48 Members):
Forums >> Revit Building >> Technical Support >> Split Faces & Decals
I have a wall with two paint colors and a piece of artwork as the dividing line. I used Split Face to divide the wall and the Paint tool to apply the color to each side of the line. Everything rendered beautifully (image 1). I then continued to add the Decal to the wall face. Everything looks great in the model (image2), but when I went to render it's as if the split face was ignored and only one of the two colors at random were rendered on the entire wall (image 3). Any suggenstions on this matter would be greatly appreciated. Thank you.
Could this be your transparecy settings for the image?
I've never done an image that was not a full rectangle so I need to experiment with this. Were the non-image areas set to transparent in your jpg?
Does this image have a bump patterN?
Modifying Slab deletes split faces |
Thu, Mar 3, 2016 at 3:04:39 PM
Decals not rendering |
Wed, Aug 17, 2011 at 11:00:09 AM
Can't split certain faces |
Thu, Dec 6, 2012 at 6:59:31 AM
Split Faces |
Tue, Dec 20, 2005 at 11:14:27 PM
split face tool on curved extrusion |
Thu, Nov 20, 2008 at 3:33:50 PM
13
Members: | 2030791 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
