112 Users Online (110 Members):
Forums >> Revit Building >> Technical Support >> Footing in section view
![3.5 Stars: 3 Votes](/images/stars_3.5.gif) |
Good evening everyone.
Could enyone please help me to understand how to mare a key in the section view of the wall strip footing?
I mean this depression in the footing where wall key is "inserted"?
Thank you very much.
Use a detail element or edit cut profile in section view.
Thank you! I found it.
As I see, it is only view-specific, and there is no 3D solution.
Do i understand it correctly that i should redraw both the wall and the footing in each section view?
Regards,
E.T.
Yes, it is a 2D solution.
No - don't redraw. I would use the edit cut profile tool. Under VIEW.
Thank you very much. It works.
Have a good day.
E.T.
section view |
Thu, Nov 8, 2007 at 6:08:57 PM
can't put enough eccentricity to center footing on wall |
Tue, Mar 5, 2019 at 4:58:08 AM
Modify Floors in Section |
Thu, Mar 3, 2011 at 2:04:49 PM
newly created wall footing won't joint |
Mon, Nov 3, 2008 at 10:02:11 AM
Continuous Wall Footing ? |
Thu, Aug 23, 2012 at 1:59:47 PM
13
Members: | 2022458 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
