70 Users Online (69 Members):
Forums >> Revit Building >> Technical Support >> Problems with selecting mullion on curtain grid
1 Posts No Rating |
I have a storefront in my project. I want to replace the glazing panel with a storefront door. When I try to select the glazing panel it will not let me select the panel or any of the mullions. I can, however, select the grid itself and the storefront as a whole. I cannot window select and filter out the the mullions or panels themselves. I then opened the project on another machine in the office and the storefront system works as it should and i have no problems selecting mullions.
Is this a setting I may have inadvertantly selected or deselected? I am currently working in Revit 2014.
In 2014-15 you can turn on a setting under the Modify tool so that you aren't able to select pinned elements, try that first. Did you also try tabbing to the element you are trying to pick?
1 Posts No Rating |
The box for selecting pinned items was unchecked. This was the problem. Thank you so much for the help, it saved me hours of headache searching.
Have a great day!!
![AlphaDDC07 Avatar](user_avatar/101170.jpg)
![4 Stars: 6 Votes](/images/stars_4.gif) |
Some times it's the simplest of things that frustrate you in Revit lol
Twelve highlanders and a bagpipe make a rebellion.
mullion with profile won't center on curtain grid |
Thu, Jun 12, 2014 at 3:00:17 AM
Curtain Grid Problems [ 1 2 ] |
Wed, Apr 10, 2013 at 5:57:45 AM
19
Curtain Mullion - Curtain Grid |
Wed, Jul 24, 2013 at 8:19:24 AM
mullion placement side/ curtain wall grid |
Tue, Nov 17, 2009 at 11:24:45 AM
Mullion Join Glitch - Adding Curtain Grid Breaks |
Thu, May 14, 2015 at 4:18:02 PM
Members: | 2016954 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
