27 Users Online (26 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Matching Room Numbers in Area's and Room Tag
Tue, Jun 10, 2014 at 10:46:07 AM | Matching Room Numbers in Area's and Room Tag
blue442
blue442 Avatar
So I’ve been looking around in revit's help, searching the web, and checked reviticty.  I'm either using bad search terms or not seeing the answer (or overlooking it?)
it seems like this is really simple...
I'm looking to create area plans for Rentable SF.  These are for numerous spaces within a plan (like a mall).  I have already tagged my room names and assigned numbers.  When I begin creating an area plan, it automatically generated an entire single space.  Since I did not want 1 gross space, deleted this and created individual areas based on my wall locations and face of glass.  Now however the Room number and Area number do not link together.  The Room name and Area name also do not link together.
Is there a way to make them work together? Or am I stuck re-entering all this information again?  In some cases we'll have to make 2-3 different area plans using different calculation methods.  I'm hoping there is a solution I can't find.
Thu, Jun 12, 2014 at 9:37:14 AM | Matching Room Numbers in Area's and Room Tag
Sorry - Areas and Rooms ARE two seperate entities and they will not share the same information.
Thu, Jun 12, 2014 at 10:12:08 AM | Matching Room Numbers in Area's and Room Tag
blue442
blue442 Avatar
That is unfortunately what I had found. Was hoping there was a way to link them since we do a lot of room based calculations.
Guess I’ll have to just re-enter the information for scheduling purposes.
Thanks
Room tag not showing in only one room. [ 1 2 ]
Fri, May 9, 2025 at 1:18:00 AM
27
Room numbers
Fri, Jan 20, 2006 at 3:27:25 AM
Editing a room tag
Thu, Oct 12, 2017 at 3:17:41 PM
Room Numbers in Schedules
Wed, Jan 25, 2006 at 3:26:56 PM
Room Tag with Occupant Load
Thu, Feb 5, 2009 at 1:58:51 PM
Page generation time: 0.7461
