41 Users Online (39 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> positioning of the dimension text
Mon, Jun 9, 2014 at 10:15:15 PM | positioning of the dimension text
megaton
Hello all,
When dimensioning walls, i am having to individually move each dimension text in roder to reduce the clutter. Can someone please show me how to set default settings so dimension text appear as follows.
Cheers.
Thu, Jun 12, 2014 at 9:35:19 AM | positioning of the dimension text
It appears you are using the correct process.  This can only be manually done.
Thu, Jun 12, 2014 at 11:36:58 AM | positioning of the dimension text
SBme
The dimension text always comes centered on the dimension line. If it is too cluttered, you have two options:
1. You might want to either change the scale. If you have too many dimensions that you have to keep adjusting, this might indicate that the detail or drawing needs to be at a different scale.
2. Or you can also tweak how the dimension displays. For example I generally turn of the leading 0' (Suppress 0 feet), so if all you have is an inch or fraction of an inch dimension, it will not add the zero feet (3 1/2" vs 0' - 3 1/2"). You can also try (Suppress spaces).
System: Revit 2014 (update release 2) on Quad-Core Thinkpad w/ 64-bit Win7 & 8Gb Ram.
Dimension Text [ 1 2 ]
Tue, Jul 8, 2008 at 9:15:07 AM
18
Overwriting Dimension with Text
Thu, Jan 11, 2007 at 11:13:56 AM
Multiline text below dimension
Tue, May 10, 2011 at 9:32:42 AM
Dimension Text Problem
Fri, Nov 14, 2008 at 9:41:55 PM
Inserting text under dimension in string dimension
Thu, Apr 2, 2009 at 9:47:51 AM
Page generation time: 1.0272
