67 Users Online (65 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Door Schedule - schedule 2 panels in a single door
Mon, Jun 9, 2014 at 7:15:25 PM | Door Schedule - schedule 2 panels in a single door
VonBraun
Hello
I'm wondering for double doors, how would I schedule two panels each of a certain size. For example our office standard for a double door of 1800 wide is labled as 2-900 in the "width" category, How do I get revit to recognize that I have two panels and say the same thing in my revit schedule.
Using Revit 2014
Thanks
Thu, Jun 12, 2014 at 9:32:20 AM | Door Schedule - schedule 2 panels in a single door
This has been a problem from the start and there is still no automatic way to do this.  We have a pair category that we set but then we show have to show the leaf information in the remarks column.
Mon, Jun 16, 2014 at 2:53:30 PM | Door Schedule - schedule 2 panels in a single door
VonBraun
Thanks WWHub
I saw another thread where you talked about your "pair category" and to be honest didn't understand how exactly it works, but it sounds interesting.
What about this idea, I set up a parameter that counts the number of "door panels" inside my family and schedules them. This column will be along side the "width" category which I shall re-name in the schedule "panel width". This way as a user I always insert the panel width I want and the family adjusts (double doors or whatever), the schedule will count the number of leaves and the contractor will see the width and number of panels in the schedule as well the graphic legend. So they will know exactly what kind of door they are dealing with.I've sold my boss on the idea anyway.
Now my question, how do I count the number of panels in my door family? They are nested door category families. So no mixing them up with hardware (which would be generic if I ever make them) What kind of parameter should I use and how do I apply it?
Thanks
Mon, Jun 16, 2014 at 3:20:40 PM | Door Schedule - schedule 2 panels in a single door
I don't see a way to count the panels.
We have a project parameter applied to doors that is a yes/no.  We have a door width that uses that PAIR to calculate a new door leaf width.  A simple WIDTH(new) = IF PAIR (WIDTH/2), WIDTH.  This works on all doors EXCEPT unequal width doors or tripple sliders.  We are accostomed to this and we know the shortcomings so until we have a better tool, we are not changing.  Anything in the family requires that every family gets fixed and that can be a problem.
Mon, Jun 16, 2014 at 3:38:09 PM | Door Schedule - schedule 2 panels in a single door
VonBraun
I see how you do it, thanks!
Can't count door panels? Pity, I thought I could schedule the hairs on my head if I could build the family.
I'm not suggesting you change, we are setting up office doors now so I'm building in what we need or hopefully I can add it later.
Mon, Jun 16, 2014 at 3:52:45 PM | Door Schedule - schedule 2 panels in a single door
I should amend.... You can set a Value like Number of leafs.  But it would not "read" that value.  You could do like I did and make that be a project parameter if you don't want to have to fix all door families.
Mon, Jun 16, 2014 at 4:06:59 PM | Door Schedule - schedule 2 panels in a single door
VonBraun
Sorry I'm not following you. what would not "read" number of leafs. What kind of parameter would that be? I just want to count the number of instances of a nested door family. The nested family is NOT shared.
I think I'm looking for a project parameter. Well as long as I can schedule it, I wouldn't mind having it a shared parameter.
Wed, Jun 18, 2014 at 10:55:57 AM | Door Schedule - schedule 2 panels in a single door
slhill
The examples I've seen uses nested panels (and frames/hardware) in the door family and separate shared parameters for each leaf ("Width Panel 1" and "Width Panel 2".  The schedule then has two columns for width - one for each panel.  For single panel doors, the second column is blank, but for pairs this allows for differing leaf sizes.
Wed, Jun 18, 2014 at 3:53:57 PM | Door Schedule - schedule 2 panels in a single door
Roger1w
I get around this by naming my door s single double etc.
then set up schedule by name and make it say what I want
Customized Door Schedule Needs Help
Thu, Aug 25, 2011 at 5:53:10 PM
Manipulating the door schedule
Wed, Jun 26, 2013 at 10:35:34 PM
11
room names not being picked up in door schedule
Mon, Apr 21, 2008 at 10:26:49 AM
Door Schedule
Fri, Aug 17, 2012 at 7:07:51 AM
Trying to Schedule a door that lives in a Window Family
Thu, Jan 16, 2014 at 12:07:11 PM
Page generation time: 1.0266
