120 Users Online (117 Members):
Forums >> Revit Building >> Technical Support >> Central Model rolls back to previous version
8 Posts No Rating |
We're having an odd issue where our Central Model (Revit MEP 2013) is rolling back to a previous timestamp (5/30/2014 5:58 pm) every night. For the second day in a row, we are detaching the local copy (because it has all of the most recent changes) and making it the new Central file. This morning, it had once again reverted to the exact same timestamp again (5/30/2014 5:58 pm).
Any ideas?
I would not use the term "rolling back".
Timestamp is a system issue - not Revit. Did you look at the file? Is it the correct file?
If the file is truely not your latest file, then something is going on with your network - not Revit. Create a new central with a new name and see what happens.
8 Posts No Rating |
Thank you for your reply. I hesitated to use this terminology. This is what I suspected though; that it was not a Revit issue. Thanks again for clarifying.
Central Model Update issue MEP2013 |
Mon, Nov 12, 2012 at 9:09:32 AM
Central & Local Files |
Mon, Dec 21, 2009 at 8:42:07 AM
updating a revit arch model error (REVIT 12) |
Fri, Mar 1, 2013 at 4:06:42 PM
Lost Work (model has reverted back) |
Thu, May 1, 2014 at 2:38:26 PM
need help! |
Tue, Oct 31, 2006 at 7:51:26 AM
Members: | 2017117 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
