84 Users Online (83 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Stair Stringer Cutting Stair Treads and Risers See Image
Wed, Jun 4, 2014 at 10:22:50 PM | Stair Stringer Cutting Stair Treads and Risers See Image
Phaeax
When I create a monolithic stair and I adjust the stringer carriage thickness to >500 I get the result of an angle cut along my entire staircase. How do I change this setting so I can make the Carriage depth as deep as I want . . . It has its practical purposes - just not in the example I attached.
Revit 2013
Thu, Jun 5, 2014 at 7:42:00 AM | Stair Stringer Cutting Stair Treads and Risers See Image
I think nobody ever though that anybody would make monolithic stairs this thick so it was never tested to this extreme. I tested it and it does happen.
You can report this to autodesk.
Thu, Jun 5, 2014 at 7:59:38 AM | Stair Stringer Cutting Stair Treads and Risers See Image
blue442
blue442 Avatar
we had this issue with a stair as well.  we ended up just making it a model in place using a swept profile (it was also on a curve) and used voids to hack off parts on the end.  we couldnt get the monolithic stair to work.
we did not apply railings since it was a residential exterior stair (3'-0 tall).  though in this case i would probably just model them in place too since there was no stringer to attach to.
Stair stringer offset (2015)
Mon, Sep 14, 2015 at 9:19:19 AM
Monolithic stair - large construction height error
Thu, Oct 13, 2011 at 12:10:33 PM
stair help with tread AND railing
Wed, Jul 3, 2013 at 12:23:08 PM
Connecting walls to stringers / hiding treads and risers
Thu, Nov 18, 2004 at 1:20:38 PM
Stair Stringer Offset
Wed, Jul 15, 2009 at 2:20:56 PM
Page generation time: 0.5482
