23 Users Online (22 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> IMPORT 3d Wireframe and populate in Revit with structural elements
Wed, Mar 1, 2006 at 8:43:42 AM | IMPORT 3d Wireframe and populate in Revit with structural elements
elvis
Hi all,
would like to import [or better DWG-LINK] a 3d wireframe where each 3d line-element [ in all kind of angles and rotational possibilities] should represent the axis-line of a steel-profile or a composed steel-structure
is it possible to populate the imported model with parametric structural elements [like tubes or else].
waiting for your responds,
E
Wed, Mar 1, 2006 at 9:52:08 PM | RE: IMPORT 3d Wireframe and populate in Revit with structural elements
eldados
eldados Avatar
4.5 Stars: 8 Votes
you will be able to import into Revit, but it won't be parametric.
Integrator
KarelCAD
Fri, Mar 3, 2006 at 9:53:38 AM | RE: IMPORT 3d Wireframe and populate in Revit with structural elements
elvis
I do no that i can import the wireframe into revit, but what i wanted to know is if it is possible to populate those lines [in all directions] with parametric konstruktional content [profiles], and while updating the initial dwg to update the model aswell.
kind regards
E
Populate windows from gh to revit... how to?
Workflow & Implementation >> Chameleon
Thu, Sep 27, 2012 at 1:43:01 PM
Monitoring Non-Copied Structural Elements
Wed, Jun 25, 2014 at 10:27:34 AM
Replacing Structural Elements in Arch Model with Revit Structure elements
Sun, Dec 4, 2011 at 4:06:34 AM
crash when edit structural elements Revit 2015
Tue, Nov 18, 2014 at 12:24:45 PM
Structural elements are disjoined
Tue, Feb 8, 2005 at 5:17:37 PM
Page generation time: 2.1586
