84 Users Online (80 Members):
Forums >> Community >> Newbies >> CAD text
Hello Revit Guru's
Am trying to import spec notes done in Autocad into revit. when I import the text gets distorted. how can I get the formating stay the same as in CAD? Any Ideas?
You will not get the formatting to stay the same.....Revit does not honor text formatting.
If it is a bunch of text that you don't want to re-write in Revit you could make a .jpeg of it and insert it in.
Thanks Teafoe5. Only negative with that is that when you run a pdf, the files become too large. I am hoping Autodesk will continue to work on the text formating and bulleting. Autocad is good with some of the 2D concepts. I love revit thogh. it has revolutionalised BIM!
Depending on how much you have to do, you might paste all of your text in a notepad file to strip out the formatting, then copy - paste into a revit text and re-format.
Linking CAD - Text Sheets |
Wed, Mar 18, 2009 at 5:42:15 PM
RAC 2009 - Text in CAD file is not plotting? |
Wed, May 27, 2009 at 9:27:50 AM
Text formating in CAD link |
Fri, Mar 15, 2013 at 9:52:22 AM
Exporting Text to Distinct Layers in CAD |
Mon, Jan 10, 2011 at 8:56:36 AM
editing CAD text |
Thu, Apr 10, 2008 at 3:12:59 PM
Members: | 2068782 | Objects: | 23094 | Forum Posts: | 152258 | Job Listings: | 3 |
