95 Users Online (94 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Vertical line-based detail component?
Tue, Jun 3, 2014 at 2:08:08 PM | Vertical line-based detail component?
MessCE
Hi -
I'm attempting to modify the Revit-standard line-based detail component for cold formed joists and make one for cold formed metal studs for wall sections.  I'm close, but even though I've set my reference plane properties to top and bottom, and I've updated the reference line to be vertical, it still wants to be placed left-to-right when I load it into my project... I'm not sure whether this is just a quick fix that I'm not seeing or if it's just not possible to set a line-based component to be vertical?  The detail component family is attached.  Thanks for your help.
Tue, Jun 3, 2014 at 2:30:53 PM | Vertical line-based detail component?
Why line based?
Just creat a detail component.
Line based Detail Component with clean-up?
Thu, Feb 3, 2011 at 3:07:01 PM
2d detail component in 3d wall-based electrical family
Tue, Sep 27, 2011 at 10:17:32 AM
Revit 2023 - Line-based Detail Component with mask
Thu, Nov 9, 2023 at 5:57:04 PM
Line-Based Detail Families - Pick Line Option Gone?!?!
Mon, Sep 5, 2011 at 8:25:00 AM
2d Line Based compnents - rotate hatch region for plan and section
Tue, Jan 31, 2012 at 9:28:27 AM
Page generation time: 3.3566
