40 Users Online (39 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Window architraves on the wall, angled wall end
Thu, May 29, 2014 at 11:42:02 AM | Window architraves on the wall, angled wall end
edisonas
Hello,
I am transferring a project from autoCAD to Revit and I faced the problem, where the existing house has architraves arround the windows and doors.
Could you help me to achieve the visual effect on this?
Thanks in advance!
Thu, May 29, 2014 at 11:47:49 AM | Window architraves on the wall, angled wall end
I assume these go over the door as well.
You have several options.
  • Edit your door family and include them as sweeps there.
  • Create a face or wall based family (parametric width &height?
  • Do in-place sweeps (wall category)
Fri, May 30, 2014 at 3:25:23 AM | Window architraves on the wall, angled wall end
edisonas
Thank you for your reply.
As it is a part of the wall, probably would be a good idea to choose option 2 or 3. Just, I think, those two options won't react if door/window size will be changed and will have to be changed manually. Is it rigth?
Thanks
Fri, May 30, 2014 at 9:17:31 AM | Window architraves on the wall, angled wall end
The first will react with the door change.
The second will not be in the wall category and could be placed in the door family so it too could be automatic.
Only the third option can be in the wall category but it will not act like a wall because it will not have layers unless you create them seperatly while creating the family.  This in-place will not automatically react to door size change.
Mon, Jun 2, 2014 at 6:34:09 AM | Window architraves on the wall, angled wall end
edisonas
I will try one of them. Many Thanks.
create a wall sweep on an angled wall (gable end wall) (2017)
Wed, Aug 3, 2016 at 2:29:53 PM
Angled Wall Sweep End
Thu, May 7, 2009 at 10:56:28 AM
REVIT 2013 - Angled Layered Wall Ends
Tue, Dec 3, 2013 at 8:18:33 AM
Revit 2011, Creating a wall with an angled end.
Wed, Feb 7, 2018 at 10:55:53 AM
How do I create an angled bay window with a wall above and below
Thu, Jul 22, 2004 at 4:07:00 AM
Page generation time: 1.0605
