53 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Align texture on In-place component
Fri, May 23, 2014 at 9:29:29 AM | Align texture on In-place component
KCren
The shingles on the roof don't match up. I used the texture alignment and tried to align the pattern. This method works on flat surfaces which I have done successfully before.
However this is an in-place component comprised of sweeps and extrusions. The surfaces are curved and multiple pieces. I cannot move the pattern tiles using the align tool. Aside from creating a seperate texture for each surface is there a more convinient method to line up the patterns?
Model in place component
Wed, Oct 11, 2017 at 11:46:06 AM
How to rotate a familly and have its texture rotate with it ?
Thu, Jul 19, 2012 at 1:00:20 PM
Revit wont align siding
Fri, Dec 2, 2011 at 8:46:34 AM
rotating detail component
Tue, May 27, 2008 at 7:39:41 AM
ARCH OPENING IN IN PLACE WALL COMPONENT
Thu, Jun 14, 2012 at 2:04:07 PM
Page generation time: 0.6511
