52 Users Online (52 Members):
Forums >> Revit Building >> Technical Support >> Revit to autocad
52 Posts No Rating |
Hi,
I need to export revit sheets,views to autocad. But when i export all the colours for componets walls etc will change in autocad file.if window is yellow in revit it will be magenta and so on. and also the line weights,text fonts all are changing.How do i avoid these.
Thanks
You need to set your export layers file up.
All colour export definitions are set in there. Different colour id's can be given depend if the object is being shown in project or cut.
HTH.
If you've done this and you are still experiencing issues. Try turning on or off your override host layers.
AutoCad vs Revit [ 1 2 ] |
Thu, Aug 4, 2011 at 1:58:52 PM
16
Why doesn't reivt have the simple autocad commands that we know and love. [ 1 2 ] |
Thu, May 7, 2009 at 1:22:38 PM
15
Autocad details linked into Revit |
Mon, Jun 6, 2016 at 1:54:23 PM
Revit MEP or AutoCad MEP |
Fri, Oct 14, 2011 at 8:21:49 AM
Revit or AutoCAD? |
Mon, Feb 22, 2010 at 2:49:07 PM
Members: | 2022361 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
