113 Users Online (111 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> navisworks switchback
Thu, May 22, 2014 at 2:15:37 PM | navisworks switchback
vinnygolfer
4.5 Stars: 4 Votes
hi all. working with Revit and Navisworks 2014. had anyone had good luck using the switchback feature for exporting and revising the model? if so, please share your process. i have tried, but have issues with it. if i'm viewing the model in navisworks, i highlight a component and then press the switchback. when it opens up in Revit, it opens with the same camera angle, which usually puts me in the next room, or upstairs and i can't see the item. and Revit opens like 5 windows for some reason. i would like to figure out how to use it productively. i can see the benefit of looking at a problem spot in Navisworks, and going right to that spot in the Revit model to fix it, but i can't seem to make it work.
Try to learn at least one new thing every day
Mon, Jun 9, 2014 at 1:47:27 PM | navisworks switchback
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I have never had full success with the switchback process. It's problematic and somewhat unpredictable. Especially with central files. It's a half baked tool. In other words it's not quite ready for production and needs to bake in the oven a little longer.
Mon, Jun 9, 2014 at 1:52:16 PM | navisworks switchback
vinnygolfer
4.5 Stars: 4 Votes
i'm glad to see that i'm not the only one that finds it hard to use.
Mon, Jun 9, 2014 at 2:07:42 PM | navisworks switchback
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
. . . . not ready for production use. The clash detection itself however works awesome. Just stay away from switchback until further notice.
Wed, Apr 20, 2016 at 10:25:46 AM | navisworks switchback
HermanMunster
I am using Navisworks manage 2016 and Simulate 2016 and both switchbacks work well in a detached or Central File model. Hope this has changed for you both
Switchback stairs, stringer problem
Wed, Jul 15, 2009 at 2:30:15 PM
Casper the Friendly Ghost Add-in NavisWorks 2016
Mon, Apr 25, 2016 at 5:01:18 PM
NavisWorks Exporter
Mon, Mar 28, 2011 at 3:40:01 PM
Export Issue from revit to navisworks
Thu, Apr 15, 2010 at 9:14:19 AM
2016 export Revit files to Navisworks without using Navisworks Exporter.
Thu, Apr 21, 2016 at 4:53:16 PM
Page generation time: 16.7720
