Forums >> Revit Building >> Technical Support >> Staggered tile PAT file needed: 96" W x 21" H
Hello! hope everyone is enjoying revit!
how is a staggered tile pattern created? i am in need of a staggered tile pattern that is 96" Wide x 21" High. Any help
would be greatly appreciated. i ma running revit architecture 2015, updated release 2
thank you
When you say staggered, do you mean like a block pattern? If so, then now is a good time to learn. Find a copy of the concrete 8x16 block pattern and edit it to your 21 x 96 pattern. Really very easy and once you do it, you can make as many staggered patterns as you need. Just edit the .pat using a simple text editor and rename it when saving, then load that pattern file.
Here is a simple running bond pattern - create a new one using notepad;
*10.5x15 Stretch running bond;%TYPE=MODEL0, 0,0, 0,10.590, 0,0, 10.5,7.5, 10.5,-10.5
Change the 10.5 to 21 and the 7.5 to 48 (1/2 of the length)
This is a model pattern.
Save with a .pat extension.
thank you soooo much!
oops ... when I pasted this in, the returns did not show.
;%TYPE=MODEL
0, 0,0, 0,10.5
PAT file: 12 x 24 staggered tile |
Tue, Mar 21, 2017 at 11:45:09 AM
Custom model tile pattern |
Fri, Jul 1, 2016 at 5:29:27 PM
Import PAT File |
Tue, Dec 14, 2010 at 9:42:43 AM
help with .pat custom file. |
Mon, Oct 13, 2008 at 8:25:57 AM
How do i make an allternating horizontal 4" and 8" .pat file in notepad??? |
Tue, Sep 6, 2011 at 6:32:54 PM
Members: | 2017072 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
