138 Users Online (137 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Random Elevations Not Printing
Thu, May 15, 2014 at 4:49:53 PM | Random Elevations Not Printing
jenhiser
I am using 2014 and have created interior elevations from my floor plans.  Some of the elevation views do not print.  They look fine on screen, but do not show up on the pdf or on prints.  It appears to be random because I created each elevation view similarly and did not change any property settings.  I have also tried deleting the elevation view and creating a new view, but it has the same problem.  Oddly enough, the tags, dimensions and crop lines will print.  See my attachment for an example.
Thanks,
Jenny
Fri, May 16, 2014 at 7:33:49 AM | Random Elevations Not Printing
Do you mean the view in the upper left corner?  You should be more descriptive instead of making us guess.  This business is all about communication.
A comparison view of your screen image may have helped us.  If that is the view, then also post us an image of the view properties.
Fri, May 16, 2014 at 8:12:55 AM | Random Elevations Not Printing
archigrafix
5 Stars: 4 Votes
Are all the views hidden line (for instance)? Or does the view with problem have shading or shadows? It could be converting to raster and be related to that.
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
Fri, May 16, 2014 at 7:42:49 PM | Random Elevations Not Printing
dano3d
3.5 Stars: 3 Votes
I've had a similar problem with parts of my drawing not printing. My conclusion has been an inadequate graphics card. A temporary solution has been to turn on the "Hardward Acceleration" in the options tab which solves the printing, but it's a pain in the butt because it doesn't take affect until you restart your Revit session. For the record, I'm still using Revit-2013 and sadly need a computer upgrade.... but that's another story. I've attached a pdf showing directions to the Hardware Acceleration if your unsure of the location.  Maybe this will work for you.  Good luck!  Dano3d
Mon, May 19, 2014 at 8:46:26 AM | Random Elevations Not Printing
jenhiser
Thanks for the responses.  The attachments below show a screen shot of the example view as well as the graphic display options.  All of the views are hidden line and I am printing with vector processing in grayscale.
I tried turning off the hardware acceleration, but to no effect.
Any other ideas?
Mon, May 19, 2014 at 9:03:07 AM | Random Elevations Not Printing
No graphic display options were included.
Your original post said "...Some of the elevation views do not print...".   Did you mean there are other instances of this?  Was this random?  Did it change?  If there are other instances, did you compare the view properties for the affected views?  Pay attention to view templates and apply a different template if possible.
I have see corrupted views on sheets and I had to delete th view and create a new one.  Create it first and copy paste same place all annotations before deleting the old one.
Mon, May 19, 2014 at 7:06:52 PM | Random Elevations Not Printing
dano3d
3.5 Stars: 3 Votes
I agree with WWHub. Another thing to try is put the problem view on a sheet alone in a different position to test that it may be a printing issue and NOT a Revit issue. Sometimes you need to think like Sherlock Holmes to solve "Revit Crimes".  Dano3d
Tue, May 20, 2014 at 9:02:54 AM | Random Elevations Not Printing
jenhiser
Thanks for the help.  It was 2 views that I was having trouble with.  I deleted the view (one shown in the attachments) and redrew the elevation.  That seemed to do the trick although I still do not understand why this wasn't printing.  The other view was not printing the tile pattern, but I realized that I inadvertently had 2 walls on top of each other.
Revit 2010 printing random lines
Mon, Jan 4, 2010 at 10:51:09 AM
some keynotes not printing
Thu, Sep 15, 2016 at 4:43:39 PM
Room Color Fill Not Printing, Random Circle is
Wed, May 17, 2006 at 6:20:12 AM
Random Walls not printing the Pattern
Thu, Feb 20, 2014 at 9:21:34 AM
Printing Shaded Elevations to PDF
Wed, Oct 19, 2011 at 11:23:07 PM
Page generation time: 0.8646
