56 Users Online (56 Members):
Forums >> Revit Building >> Tips & Tricks >> How to make Panels overlap Mullions & how to add gaps between those panels???
0 Posts No Rating |
Hey guys... I want my panels overlap mullions because when I add a corner mullion, it simply put away my painels and that's terrible... take a look in attachments.
(I want glass painels to be IN FRONT of mullions)
Edited on: Tue, May 13, 2014 at 6:43:10 PM
Edited on: Tue, May 13, 2014 at 6:43:33 PM
Edited on: Tue, May 13, 2014 at 6:43:53 PM
You can make gaps by making mullions made of "air" material and turn their visibility off.
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
0 Posts No Rating |
But the problem is: it is offsetting to inside... I need to offset panels to outsite, to overlap the mullions
0 Posts No Rating |
Hi
1. Create a curtain wall type with border mullions with width corresponding to the halfwidth of the joint you want.
2. Use this curtain wall type as a curtain panel in type properties for the main curtain wall that you want to create. Now you have nested curtain wall as panels.
3. Add mullions to the curtain wall, offset them to move them behind the nested panels.
This is how you can achieve the effect in the attached picture.
4. This will work only with vertical curtain walls, so it is not universal workaround for any type curtain system (sloped walls, roofs, etc.)
Have a nice day modelling in Revit
Turning certain curtain panels into spandrel panels |
Tue, Dec 3, 2013 at 1:59:47 PM
Curtain-panels - Need to alter extents |
Tue, Jun 2, 2015 at 8:11:44 AM
Curtain wall panels not trimming correctly against mullions |
Thu, Dec 10, 2009 at 5:49:55 PM
curtain walls make like partition walls |
Sun, Oct 26, 2008 at 9:23:37 AM
11
Double layered curtain panels |
Thu, Mar 12, 2009 at 6:48:32 AM
Members: | 2056134 | Objects: | 23069 | Forum Posts: | 152281 | Job Listings: | 3 |
