63 Users Online (62 Members):
Forums >> Revit Building >> Technical Support >> Trim and frame does not adjuts to wall as expected
26 Posts No Rating |
I have created my 6 panel door. My frame adjust to the varing door widths but will not adjust to a new wall thickness. Also, I can't seem to get my trim to adjust to varing door sizes. I haven't placed it in a project with the trim on it yet but I presume that the trim won't adjust to different wall thicknesses either. Any help would be appreciated.
J
![3 Stars: 1 Votes](/images/stars_3.gif) |
Again you'll probably have to post the file.
![eldados Avatar](user_avatar/6083.jpg)
![4.5 Stars: 8 Votes](/images/stars_4.5.gif) |
go to your family and make sure that the frame is locked to the wall reference lines, same with your trim...
Ok here is the file. I would like to make the jamb and trim adjust to a varing wall thickness and the trim also needs to adjust to varing door widths. If you can let me know how to do it that would be great. I don't nescessarily want anyone to fix it for me, I won't know how to do it if that happens.
Thanks for all the help!
J
I had to add reference planes to the Exterior and Interior Finish. I then removed your trim sweeps and redrew them with the Exterior and Interior Finish as the working planes.
To get the Jamb and Door panel to stretch with the wall I had to lock dimensions from the Interior Finish working plane to each element of the jamb and door panel.
Hope that helps.
Post edited on 2006-03-01 12:26:09
flip control only door panel & not frame/trim revit 2015 |
Mon, Apr 27, 2015 at 10:19:19 AM
Control Position of Door Frame/Panel in Wall Thicker Than Door Frame |
Thu, May 6, 2010 at 7:29:41 AM
wall trim under an eave |
Wed, Feb 8, 2006 at 12:15:12 PM
Vertical trim ***PLEASE HELP**** |
Tue, Jun 12, 2012 at 8:05:22 PM
Stone wall covers door and window trim? |
Thu, Jan 3, 2008 at 8:50:32 AM
Members: | 2016919 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
