72 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Does revit can export data via ODBC to Microsoft Project.?
Tue, Sep 16, 2003 at 1:40:54 PM | Does revit can export data via ODBC to Microsoft Project.?
Tanapong
Does revit can export data via ODBC to Microsoft Project.? if so,I thought it's would benefit to construction management.
Fri, Sep 26, 2003 at 12:29:56 AM | RE: Does revit can export data via ODBC to Microsoft Project.?
FreeRangeMonkey
Revit can export an ODBC database to any ODBC source, including, theoretically, Project. I have not tried this, however.
Wed, Oct 27, 2004 at 8:28:46 PM | RE: Does revit can export data via ODBC to Microsoft Project.?
ale02
ale02 Avatar
3 Stars: 3 Votes
I always want to try out this and finally I did. My conclusion. Yes. Revit can export data to Project but not directly. From my 3 tests, 1. Export direct to Microsoft Project don't work, 2. Export ODBC thru MS Excel don't work 3. Export thru Access can be done. Once you export your Revit Project into Access Database, Open up your Microsoft Project>File> Open> Click on the small button for ODBC> Browse to your Previous save Access File & Microsoft Project will run thru the export wizard. My try out eventually stop here because I hit with a roadblocker. Error Messages appear after I was trying to mask some of the category.... More try out after this are required as in Access Database, it split up all the revit family/ objects into individual ID. I doubted in MS Project required all of those to be presented but I believe cost & assignee can be proved very useful in MS Project if those items can be grouped. How to mask all the revit family/ type/ element into task also are foreseen will be a very complicated task. Though I am yet to try out those. Hope to see more experience sharing from this particular area..prehaps from those who are well verse with database
ODBC Export Error Access
Wed, Apr 22, 2009 at 11:32:47 AM
ODBC Export with Sheet Names and Numbers
Tue, Aug 12, 2014 at 9:54:33 PM
[Revit Structure 2009] Create 'Type Catalog' of existing family-types
Wed, Apr 1, 2009 at 9:18:17 AM
ODBC Database.....Help
Wed, Aug 16, 2006 at 10:27:34 PM
Setting up ODBC Export with Open Office Base
Tue, Mar 8, 2011 at 5:32:11 PM
Page generation time: 2.5458
