67 Users Online (64 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> EXPOR LAYERS for WALL HATCHES are missing
Tue, Feb 28, 2006 at 12:25:18 PM | How to export Wall Hatches in a seperated layer for autocad
elvis
hi all,
I am trying to export to dwg using a layer conversion, but we figured out that all Wall related parts are exported in one category. We need the outher/inner wall lines in a layer and the wall "CUT" pattern in a different layer [like the surface pattern, this IS posible]. how to get the wall cut pattern in a different layer then the other wall elements?
grtz
E
Post edited on 2006-02-28 12:25:59
Post edited on 2006-02-28 12:27:50
Tue, Feb 28, 2006 at 7:51:16 PM | RE: EXPOR LAYERS for WALL HATCHES are missing
arccodex1
3 Stars: 1 Votes
While in AutoCAD you can Quick Select... Object Hatch... and switch them over to a new layer.
Wed, Mar 1, 2006 at 3:06:50 AM | RE: EXPOR LAYERS for WALL HATCHES are missing
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
This is not possible currently.
Wed, Mar 1, 2006 at 8:30:59 AM | RE: EXPOR LAYERS for WALL HATCHES are missing
elvis
ok thanxs, so off for the wish-list, grtz E
wall layers not wrapping at curtain wall inserts!
Fri, Mar 4, 2016 at 10:27:09 PM
Export to DWG: distinguish Wall hatches from the inner and outher wall lines
Wed, Mar 1, 2006 at 8:34:42 AM
Wall Layer Grips Missing
Wed, Dec 2, 2015 at 8:37:53 PM
PROBLEM WITH WALL HATCHES
Wed, Mar 16, 2011 at 5:25:55 AM
Scheduling Wall Layers
Wed, Nov 4, 2015 at 11:24:09 AM
Page generation time: 1.1566
