43 Users Online (42 Members):
Forums >> Revit Building >> Technical Support >> adaptive on path is rotating
23 Posts No Rating |
using revit 2014,
i was making a rail on a curvy path. ( please refer to the attachment ) . but in some places the adaptive component rotates .. anyone knows how to fix it !!!
I removed your other post because you started this new thread.
I don't think your image tells us anything. You should hide everything but what we need to see to understand.
Edited on: Thu, May 8, 2014 at 7:38:37 AM
ok check this image i hope it is more clear....
It seems like there is no answer for my question !
HELLOOOOO...
Still not clear ??
One tip from your HELP menu: "The order of point placement is important. If the component is an extrusion, the direction of the extrusion will flip when the points are placed counterclockwise."
yes ur right in case i am doing and extrusion .. but i am doing a repeat for an adaptive component on a 3d path which is a deferent story.
26 Posts No Rating |
Did anyone ever solve this? I'm having the same issue
The end of my component twists when I place it.
scotty v
actually at the end i ended up with splitting the path into many segments. and this solved my problem . but am not sure you are having the same exact issue . are u ?
adaptive components |
Fri, Jan 23, 2015 at 7:12:31 AM
Problem with a rectangular section on an adaptive arch |
Tue, Jul 16, 2013 at 7:21:17 PM
A solution for roads and paths |
Fri, May 3, 2013 at 5:17:48 PM
Adaptive Component - Flaky Arc |
Tue, Feb 9, 2016 at 1:26:48 PM
annotations on adaptive components? |
Thu, Jan 24, 2013 at 6:21:59 AM
Members: | 2022374 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
