102 Users Online (101 Members):
Forums >> Revit Structure >> Tips & Tricks >> Putting out drawings & Dodging bullets
We area working on this qiute large airport terminal and it changes references levels from area to area, sometimes while in the same area! which = elevation tags are no fun. A way to prevent having to put out revised drawings because your elevations are off, becaused they are based off of "associated level" parameter, which is only editable from step one of creating the view off the level that its associated with, is everytime you go into the "spot elevation" tag you could have to remember to switch the level you would like to reference, or another, less demanding, technique can be administererd. you can create a shared parameter for your sheets, called "elevation reference" and make a drawing note on your title block that has everything around that parameter already filled out in text notes, and have a label referencing that shared parameter, and your title block will update once you go to the properties of the sheet and fill out your name and elevation of the level you wish to "associate"' to your spot elevations. Once you fill the information out once, it becomes a drop down for future sheets, just like your "drawn by, or "checked by" parameter thats premade. Just FYI, hope it helps someone out there.
Bullets & Numbering in Text Boxes |
Thu, Oct 16, 2014 at 11:20:06 AM
Text formatting (bullets & indents) |
Wed, Jun 11, 2008 at 8:49:15 PM
Controlling Bullets/Line Spacing |
Tue, Apr 7, 2015 at 8:41:49 PM
elevation bullets handle |
Wed, Jun 8, 2016 at 3:08:08 PM
Reference to non - Revit drawings |
Wed, Mar 19, 2008 at 6:18:54 AM
Members: | 2017174 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
