147 Users Online (145 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> I need to change my building levels from 0'-0" to 100'-0"
Tue, Feb 28, 2006 at 9:38:08 AM | I need to change my building levels from 0'-0" to 100'-0"
Rugrat
Is there an easy way to do this without getting into a major undertaking?
Tue, Feb 28, 2006 at 10:09:39 AM | RE: I need to change my building levels from 0'-0" to 100'-0"
TomDorner
4.5 Stars: 25 Votes
Assuming you are not talking about a model linked into a seperate site project, then go to elevation view or any view you can see all the levels, dimension the levels and lock the dimensions, change level 0'-0" to 100'-0" and everything should move up. HTH Tom
Tue, Feb 28, 2006 at 10:15:20 AM | RE: I need to change my building levels from 0'-0" to 100'-0"
Rugrat
It is even easier than that. The help menu is wrong. It leads you to the wrong place. If you set your level properties to Shared, then go to the Tools menu, there is a flyout from Project Position/ Orientation. Click on Relocate project. The Command works just like move, but everything in your project moves to the new position. You can move everything at once to anywhere. Thanks Post edited on 2006-02-28 10:59:25
Tue, Apr 4, 2006 at 5:21:54 PM | RE: I need to change my building levels from 0'-0" to 100'-0"
medmonds
How does this work with huge Revit files that have tons of linework, notation, all the CD sheets setup, etc? Is there any danger that some stuff will not move?
Tue, Apr 4, 2006 at 5:27:46 PM | RE: I need to change my building levels from 0'-0" to 100'-0"
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Use the relocate project tool should be fine. There is no chance of it effecting any of your views. All its doing is relocating the co-ordinate system rather than moving the building...
Fri, Apr 7, 2006 at 5:03:45 PM | RE: I need to change my building levels from 0'-0" to 100'-0"
mhildebrandt
I need to do the same thing (switch levels from 0-0 to 100-0) but I want to keep it so spot elevations on my topo read as their true elevation. Is this possible? When I relocate, the topo elevations get 100 added as well. My levels are set as project levels.
Sat, Apr 8, 2006 at 7:55:58 PM | RE: I need to change my building levels from 0'-0" to 100'-0"
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Yes this is possible. You can have levels set as shared or project (located in their properties). This enables you to have you levels report starting at RL 0 for instance whilst your topo contours still report the appropriate real world elevation.
Sun, Apr 9, 2006 at 12:34:27 PM | RE: I need to change my building levels from 0'-0" to 100'-0"
mhildebrandt
Yah, I know about shared vs. project levels, but how do I get Level 1 to read as 100 instead of 0? Relocating the project alters the shared coordinate system, leaving my Level 1 as 0-0 and adding 100 to my spot elevations. This is the opposite of what I want to do. Is there a way to shift the project coordinate system? I've tried locking the levels together and then typing in 100 for level 1 but this floats the building 100 ft in the air.
Sun, Apr 9, 2006 at 6:30:18 PM | RE: I need to change my building levels from 0'-0" to 100'-0"
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
In your spot elevations and you levels there are settings to change whether its uses the shared elevation or the project elevations. Switch them around as required. Spot Elevation-->Properties-->Elevation Origin... Level-->Properties-->Elevation Base...
Mon, Apr 10, 2006 at 9:11:47 AM | RE: I need to change my building levels from 0'-0" to 100'-0"
mhildebrandt
Thanks for the help. I think I'm not being clear. My spot elevations are shared elevations, and my levels are project elevations. The spots are working correctly right now and Level 1 reads 0-0. Our firm standard, however is for level 1 to read as 100-0. Is there a simple way to change the default value for level 1?
Mon, Apr 10, 2006 at 9:30:13 PM | RE: I need to change my building levels from 0'-0" to 100'-0"
#11
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Can't you just create a new level type for level 1 only that uses the shared levels instead of the project level...
Fri, Sep 1, 2006 at 4:02:19 PM | RE: I need to change my building levels from 0'-0" to 100'-0"
#12
mattchu
That changes the level to read the elevation of the toposurface which in my case is 5410'-0". and I want it to read 100'-0". Am I misunderstanding what you're saying?
Sat, Sep 11, 2010 at 8:03:55 PM | I need to change my building levels from 0'-0" to 100'-0"
#13
rkitect
rkitect Avatar
4 Stars: 29 Votes
Matchu, give this a shot and see if it helps:
http://revittotd.com/06/340
Let me know if you have any questions.
Change 0'-0" MAIN LEVEL to 100'-0"
Tue, Aug 22, 2006 at 7:40:49 PM
Changing Levels from 0'-0" to 100'-0"
Mon, Apr 21, 2008 at 2:07:48 PM
Change Base Elevation
Mon, Oct 6, 2014 at 12:11:08 PM
Printing without title block and to 1"=100'
Thu, Dec 8, 2005 at 4:58:39 PM
"Constraints are not satisfied"
Wed, Jun 7, 2006 at 8:17:24 AM
Page generation time: 2.6030
