43 Users Online (42 Members):
Forums >> Revit Building >> Technical Support >> Floor creating mode greys out all tabs
12 Posts No Rating |
Hello. Please help. I haven't been using revit almost for a year. I started to work again, I created walls then when I wanted to add generic floor modify tab became grey with no tools to sketch foor. At the same time other tabs become grey. I am attaching jpeg as an example of what happens tomodify and other tabs when I want to create floor.
What Revit version?
Did you installed Web-updates??
I am using Revit 2012. I did not update anything for almost a year. And I do not remember updating anything even before. Is my problem updates related? How do I update it? I thought updates are automatical. Thanks in advance
http://forums.autodesk.com/t5/Revit-Architecture/Autodesk-Revit-Architecture-2012-Update-2-is-now-available/td-p/3184396
I have installed web updates2. After updates I can see tools in draw palette, but stil not able to sketch a floor. Should I istall some other updates? I have never installed updates before and it worked just fine. Am I facing problems because I did not open my Revit for almost a year and thus skipped all automatical updates? Thanks in advance
You should install all updates .... in order. I believe 2012 only had 2 updates.
Can not find proper update 1. Do I also need to install Hotfixes?
Question about sketch Mode |
Thu, Jan 17, 2013 at 6:34:56 PM
Revit won't (Grey/Halftone/Fade) during any Sketch/Edit/Modify mode |
Tue, Feb 27, 2018 at 11:18:53 AM
Ribbon Tabs jumbled up |
Mon, Oct 19, 2009 at 12:07:04 PM
Floor Sketch mode |
Fri, Dec 3, 2010 at 3:46:30 PM
Can I render in Family mode? |
Mon, Mar 29, 2010 at 6:37:04 AM
Members: | 2056141 | Objects: | 23069 | Forum Posts: | 152281 | Job Listings: | 3 |
