59 Users Online (57 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> Newbies >> facade_curved wall
Thu, May 1, 2014 at 11:04:07 AM | facade_curved wall
e441
Hi,
How I can make curved wall but double facede:glass+stone cladding.But cladding is curved.
This is autocad drawing;
Thu, May 1, 2014 at 11:08:22 AM | facade_curved wall
Your elevation doesn't tell us much.   Walls can be curved including curtain walls.  The curtain wall will segment to flat segments depending on your grid locations.
Thu, May 1, 2014 at 11:18:53 AM | facade_curved wall
e441
Model is simple now. My cladding are spline so I can not do this with split face.
Thu, May 1, 2014 at 12:03:25 PM | facade_curved wall
What would you use split face for????
You will find that you can't document splines easily and they are hard to use in a lot of ways.  Standard geometry is easier to use and document so tangent arc segments work a wole lot better then splines.  And nobody except you knows the difference.
Thu, May 1, 2014 at 12:28:56 PM | facade_curved wall
e441
How I can make arc segment in curtain wall?  Was not just be a rectangular segments in curtain system? I can change spline as arc =/
Thu, May 1, 2014 at 12:31:56 PM | facade_curved wall
3 tagential arcs
Thu, May 1, 2014 at 1:02:14 PM | facade_curved wall
e441
I could not tell .I did not mean it.I want to cover stone some places on curved wall. I drow these places arc line as in first photo.
Thu, May 1, 2014 at 2:47:51 PM | facade_curved wall
rbcameron2
rbcameron2 Avatar
4 Stars: 25 Votes
What I would do would be to make 3 model masses (preferably families) and import them in.  Make them curve in plan and section like you want and then apply curtain wall to face on the upper and lower, then the stone in the remaining open void.  Again, applied to face.
RB Cameron
3D Medical Equipment
Download Revit Healthcare Models Now
Download Other Revit + 3dsMax Models Here
Mon, May 5, 2014 at 12:21:53 PM | facade_curved wall
e441
Thank you. I will try this.
Splitting a curtain wall to change the type of wall it is
Thu, Aug 6, 2009 at 12:46:43 AM
create a wall sweep on an angled wall (gable end wall) (2017)
Wed, Aug 3, 2016 at 2:29:54 PM
wall mounted toilet wall error
Wed, May 6, 2009 at 3:41:38 PM
Repeatig wall sweep vs. repeating detail - wall attached [ 1 2 ]
Sun, Dec 7, 2008 at 3:51:45 PM
19
Arched Opening in a Curved Wall [ 1 2 ]
Thu, Nov 15, 2012 at 12:32:32 PM
17
Page generation time: 1.1542
