138 Users Online (137 Members):
Forums >> Revit Building >> Technical Support >> Revit Data Extraction
0 Posts No Rating |
What I am looking for are people that I can pick their brain on how to do this in Revit. I have done a lot type of work in AutoCAD however this type of project will be my first for Revit (and this would my fifth project for my entire Revit experience)
I being pulled into a possible Environmental Remediation project that they want to use Revit instead of AutoCAD to
- build the model of the current conditions of an existing building
- then annotate points within the model to indicate locations where samples taken
- Then have those annotations contain parameters contain values that reflects desired information by the scientist; for example
- Surface ID #
- Sample #
- Location X Y & Z values
- Material of Host that the annotation is connected to. (I.E. The wall is constructed of GWB, CMU, Metal Panel, etc.)
- Export the values of those parameters out to be linked up to environmental database.
- Apply Filters to the Revit Model to visually indicate where work still needs to happen.
Like I said I am trying to see if someone has done anything remotely similar.
2 Posts No Rating |
All of this sounds like it'd be relatively simple to do within Revit. You will need to 'build' custom tags and annotations containing the parameters you want (Surface ID #,Sample #,Location X Y & Z values,Material of Host that the annotation is connected to) but there are plenty of tutorials on family creation, shared parameters, etc. The Revit help file has a lot on this.
Then you can schedule the information and export to Excel.
Using Revit2014, dragging the rest of the company with me from AutoCAD2008. When will the whining stop? |
Create a generic model, face based family that contains the shared parameters you will be using. Create a tag that reads those parameters. Place the family and tag it.
0 Posts No Rating |
Okay how do I get a parameter to report the location of the family with in the model? Much like a spot elevation can show the X, Y, & Z values.
Here is a post that discusses how this might have been done but it takes a special app.
http://www.revitcity.com/forums.php?action=viewthread&thread_id=20420
You may find some more recent posts on the subject.
0 Posts No Rating |
Thanks WWHub. That help alot.
0 Posts No Rating |
Okay I have not found how to read the Host system parameter so I can schedule it. Has this been done before? Can it be done?
Reason is that I could have somewhere up to 1800 instances in the model and I want as much automation as possible.
Can you turn lines into a solid or void extraction? |
Tue, Apr 21, 2009 at 12:34:06 AM
how do you make a family for tel data that will circuit to data board telephone |
Tue, Jan 28, 2014 at 6:39:31 PM
Revit Identity Data export to Navis |
Tue, Aug 30, 2022 at 6:23:11 AM
Room Data Sheet (inc furniture and doors) using a Room Tag |
Fri, Jan 20, 2012 at 9:47:21 AM
Linking bridge measuring data to a Revit Modell |
Wed, Jun 13, 2018 at 11:56:06 AM
Members: | 2030595 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
