36 Users Online (35 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> Revit 2014 SHEETMASS ZERO pop up issue
Tue, Apr 29, 2014 at 4:12:03 PM | Revit 2014 SHEETMASS ZERO pop up issue
mpolo297
Hi,
When opening drawing or loading family I get this annoying pop box: SHEETMASS_ZERO.
I have to click or hit <ESC> numerous times (a lot) to finaly have drawing opened or family loaded.
I'm guessing it started happening when I mirrored some building (3D model with details etc, complictated roof).
But it happens when I open other projects too.
I can't find any similar on-line thread like this.
Please, any hint is welcome (except re-installing).
THX
Mark
Wed, Apr 30, 2014 at 8:29:55 AM | Revit 2014 SHEETMASS ZERO pop up issue
The help describes what this parameter is:
http://help.autodesk.com/view/RVT/2015/ENU/?guid=GUID-CB906F43-D9EE-4BA7-B052-2864696A73CE
Perhaps you have some structural settings you need to turn off.
Edited on: Wed, Apr 30, 2014 at 12:24:19 PM
Wed, Apr 30, 2014 at 11:56:33 AM | Revit 2014 SHEETMASS ZERO pop up issue
mpolo297
Thx for reply but don't know what you mean. The issue doesn't show up in HELP.
Wed, Apr 30, 2014 at 12:25:42 PM | Revit 2014 SHEETMASS ZERO pop up issue
Sorry - the link I posted was to our internal help.  I reposted it to the 2015 help.  Click on that and read!  It is in the HELP.  2015 and 2014 are basically the same in this instance.
Wed, Apr 30, 2014 at 2:55:50 PM | Revit 2014 SHEETMASS ZERO pop up issue
mpolo297
Wow. I was way off in what this was about. Thinking 3D mass or sheet for page document.
I changed the mass to 1 and it worked. Its gone!
I never had this issue before, so something must have set it off to zero.
Thanks for the help.
Mark
Revit 2014 Issue- Dragging Views Into Sheets & System Crashes
Wed, Apr 27, 2016 at 5:47:09 PM
Revit 2014 Point Cloud Plot Issue
Fri, Apr 25, 2014 at 8:44:49 AM
Revit 2014 upgrade issue - in place families appearing black?
Fri, Jun 21, 2013 at 10:58:42 AM
grant permit request doesn't pop up
Tue, Aug 1, 2006 at 1:27:32 PM
some pop-up menus do not appear
Wed, Jun 7, 2017 at 5:37:41 AM
Page generation time: 2.7162
