82 Users Online (81 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Toilets not showing in second floor
Mon, Apr 28, 2014 at 9:48:48 AM | Toilets not showing in second floor
restender2000
My toilets are not showing on my second floor.  I changed my view range, but that did not help.
I placed a desk in the same area -- to check to see if I could see components--and that worked.
any ideas?
Mon, Apr 28, 2014 at 9:58:24 AM | Toilets not showing in second floor
They may not be where you think they are.  Cut a section in that area and look at it.
Mon, Apr 28, 2014 at 5:56:38 PM | Toilets not showing in second floor
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Sounds like plumbing fixtures are turned off in the views visibility graphic overrides or perhaps the workset that plumbing fixtures are on is turned off in the view.
carmoa toilets
Tue, Jan 15, 2008 at 4:14:57 AM
Disabled Toilets Family
Tue, Feb 3, 2009 at 5:22:32 PM
Disabled Toilets rfa files
Thu, Feb 7, 2008 at 2:58:53 AM
Objects on floor above showing
Fri, Nov 13, 2020 at 4:19:52 AM
Is it possible to copy from job to job a piping layout like back to back toilets
Fri, Sep 25, 2009 at 3:54:07 AM
Page generation time: 2.4190
